Creates an ERPS ring.
| ring-name | Alphanumeric string that identifies the ERPS ring. |
| ring-id | Specifies configuring a unique integer ID for ERPS ring. |
| ring_id | Sets the ERPS ring ID value. Range is 1 to 239. |
N/A.
Use this command to create an ERPS ring, and optionally the ring ID.
The following command creates an ERPS ring named “ring1” with ring ID "50":
create erps ring1 ring-id 50
This command was first available in ExtremeXOS 15.1.
Ring ID was added in ExtremeXOS 33.1.1.
