Deletes an entry from the ARP table.
| ip_addr | Specifies an IP address. |
| vr_name | Specifies a VR name. |
If you do not specify a VR or VRF, the current VR context is used.
Removes any IP ARP entry (dynamic or permanent) from the table. You must specify the IP address of the entry to delete the entry.
The following command deletes an IP address entry from the ARP table:
configure iparp delete 10.1.2.5
