Use this command to add entries to the mapping table and to set the map table response state for the switch.
vlan_list | VLAN ID or range of IDs (1–4,094) |
profile_index | Policy ID (1–63). |
response | Indicates which attributes to use from RADIUS response. |
tunnel | Applies the VLAN-tunnel attribute. VLAN/NSI mappings from RADIUS are used if present. Mappings in policy profile are ignored. |
policy | Applies the policy specified in the filter-ID. VLAN/NSI mappings from policy profile are used if present. Mappings in RADIUS response are ignored. |
both |
An enhanced policy option that applies either all the filter-ID and VLAN tunnel attributes or the policy depending upon whether one or both are present. VLAN/NSI mappings from either RADIUS or policy profile may be used. Mappings in RADIUS response have a higher precedence over policy profile when both contain mappings. |
N/A.
The policy response is the default response for the configure policy maptable command.
This example adds an entry to the map table that maps VLAN 3 to policy profile 8:
configure policy maptable 3 8
This command was first available in ExtremeXOS 16.1.
