Configures the maximum allowed IPv6 neighbor entries.
| max_entries | Specifies the maximum allowed IPv6 neighbor entries. The range is 1 to 49,152. |
8,192.
For ExtremeXOS 30.1, the maximum configurable limit for neighbor discovery maximum entries is changed to 49,152 for all platforms. A message appears if the configured value exceeds the theoretical hardware maximum limit depending on the platform.
The following example sets the maximum allowed IPv6 neighbor entries to 512:
configure neighbor-discovery cache max_entries 512
This command was first available in ExtremeXOS 12.4.
Per virtual router capability was deprecated and the maximum configurable limit set to 49,152 in ExtremeXOS 30.1.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
