Configures the LLDP port to advertise or not advertise the 802.1q framing configuration to its neighbors. The Avaya phone uses this proprietary LLDP TLV information. In addition to this LLDP TLV, you must enable LLLDP as well as configure both the LLDP MED capabilities TLV and the LLDP network policy TLV.
| all | Specifies all ports on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
| advertise | Specifies to send the information to neighbors. |
| no-advertise | Specifies not to send the information to neighbors. |
| tagged | Specifies to use tagging. NOTE: This parameter applies only when you use the advertise parameter. |
| untagged | Specifies not to use
| auto | Specifies following a
predetermined sequence (see Usage Guidelines below). NOTE: This parameter applies only when you use the advertise parameter. |
No advertise.
Enable LLDP using the enable lldp ports command.
Enable the LLDP MED capabilities TLV using the configure lldp ports vendor-specific med capabilities command.
Enable the LLDP MED network policy TLV using the configure lldp ports vendor-specific med policy application command.
This TLV is used to exchange information about Layer 2 priority tagging between the network connectivity device (switch) and the Avaya phone.
If you configure the TLV to advertise tagging, the phone uses tagging information, which it retrieves from the configure lldp ports vendor-specific med policy application command. If you configure the TLV to advertise untagged, the phone does not use any tagging, including 802.1q priority tagging.
Uses the configuration advertised by the LLDP MED network policy TLV, as configured by the configure lldp ports vendor-specific med policy application command.
Uses the priority tagged frames configured by the phone‘s server.
Sends the traffic untagged.
The following command configures al ports to advertise the dot1q framing as untagged to neighbors:
configure lldp ports all advertise vendor-specific avaya-extreme dot1q-framing untagged
This command was first available in ExtremeXOS 11.5.
