configure mpls delete vlan
configure mpls delete [{vlan} vlan_name | vlan all]
Description
Removes an MPLS interface from the specified VLAN.
Syntax Description
vlan_name Identifies the VLAN for which the MPLS interface is deleted.
vlan all Deletes the MPLS interface from all VLANS that have MPLS configured.
Default
VLANs are not configured with an MPLS interface.
Usage Guidelines
An MPLS interface must be configured on a VLAN in order to transmit or receive MPLS packets on that interface. If the MPLS interface is deleted, all configuration information associated with the MPLS interface is lost. Issuing this command brings down all LDP neighbor sessions and all LSPs that are established through the specified VLAN interface. When the all VLANs option is selected, the MPLS interface for all MPLS configured VLANs is deleted.
The following example deletes MPLS from the VLAN vlan_k:
configure mpls delete vlan vlan_k
This command was first available in ExtremeXOS 11.6
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
