Displays a UPM target profile configuration.
| upm_profile_name | Specifies the name of the UPM target profile you want to view. |
N/A.
None.
The following example displays the configuration for the UPM log target named testprofile1:
show log configuration target upm testprofile1
X670V-48t.1 # sh log configuration
Debug-Mode: Disabled
Log Target : memory-buffer
Enabled : yes
Filter Name : DefaultFilter
Match regex : Any
Severity : Debug-Data (through Critical)
Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condition>
Buffer size : 1000 messages
Percent Full : 60%
Full Alert : None
Log Target : nvram
Enabled : yes
Match regex : Any
Severity : Warning (through Critical)
Log Target : console
Enabled : no
Match regex : Any
Severity : Info (through Critical)
Enabled : yes
Match regex : Any
Percent Full : 60%
Full Alert : 90%
Log Target : nvram
Enabled : yes
Match regex : Any
Enabled : no
Match regex : Any
Enabled : yes
Match regex : Any
Percent Full : 100% (wrapping)
Full Alert : 90%
Log Target : nvram
Enabled : yes
Match regex : Any
Enabled : no
Match regex : Any
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
