Displays WRED and Explicit Congestion Notification (ECN) statistics for the specified ports or all ports.
| port_list | Specifies a list of slots and ports to display. Specify ports in the following formats: 3-5, 2:5, 2:6-2:8. |
| no-refresh | Specifies a static snapshot of data instead of the default dynamic display. |
| refresh | Continuous refresh of output. |
| ecn | Displays ECN statistics. |
N/A.
If no port or port list is specified, this command displays the WRED statistics for all ports. If WRED is not configured on a port, the statistics for that port display as 0.
The drop counters in the display represent packets that were dropped based on the WRED congestion avoidance algorithm. The Green Pkt Drop column counts in-profile TCP and non-TCP packets that have been dropped. The Red Pkt Drop column counts out-of-profile TCP and non-TCP packets that have been dropped.
The values in the Yellow Pkt Drop column are always 0 in this release because the yellow traffic color is not supported at this time.# show ports 2:1-9 wred no-refresh Port WRED Stats Monitor ============================================================== Port Link Green Yellow Red State Pkt Drop Pkt Drop Pkt Drop ============================================================== 2:1 A 0 0 0 2:2 R 0 0 0 2:3 R 0 0 0 2:4 R 0 0 0 2:5 R 0 0 0 2:6 R 0 0 0 2:7 R 0 0 0 2:8 R 0 0 0 2:9 R 0 0 0 ============================================================== Link State: A-Active, R-Ready, NP-Port Not Present L-Loopback
The following example shows ECN statistics for port 2:
# show ports 2 wred ecn no-refresh
Port WRED ECN Statisticss Monitor
Port Link Packets
State Marked
2 R 0
The following example shows ECN statistics for all ports:
# show ports wred ecn no-refresh
Port Link Packets
State Marked
1 A 0
2 R 0
3 A 0
4 A 0
5 R 0
6 R 0
7 R 0
8 R 0
9 R 0
10 R 0
11 R 0
12 R 0
13 R 0
14 R 0
15 R 0
16 R 0
17 R 0
18 R 0
19 R 0
20 R 0
21 R 0
22 R 0
23 R 0
24 R 0
25 R 0
26 R 0
27 R 0
28 R 0
29 R 0
30 R 0
31 R 0
32 R 0
33 NP 0
34 NP 0
This command was first available in ExtremeXOS 12.7.
The refresh keyword was added in ExtremeXOS 16.1.
The ecn keyword was added in ExtremeXOS 22.3.
