| port_list | Clears a port list. |
| port_group | Clears a port group. |
| all | Clears all ports. |
| out-of-profile | Clears only out-of-profile rate-limiters. |
| disabled-ports | Clears only ports that have been disabled due to out-of-profile status. |
| both | Clears out-of-profile status and counter for rate-limiter. |
| status | Clears only out-of-profile status for rate-limiter. |
| counter | Clear only out-of-profile counter for rate-limiter. |
All.
The clear ports rate-limit flood out-of-profile command allows the clearing of the counter and/or status of ports of a flood rate-limiter that may have had their limit exceeded. For the entered ports, the status option removes the ports from the disabled port out-of-profile list, re-enables ports that may have been disabled due to out-of-profile rate-limit, and re-enables the syslog and traps for those ports as well. For the entered ports, the counter option resets the counters. If neither option is specified, both the status and counter will be cleared. If the disabled-ports option is specified, only the out-of-profile statuses that have disabled ports will be cleared. If no options are specified, all out-of-profile statuses will be cleared.
clear ports all rate-limit flood out-of-profile clear ports all rate-limit flood out-of-profile disabled-ports clear ports fldGroupA rate-limit flood out-of-profile status clear ports 1-24 rate-limit flood out-of-profile counter
This command was first available in ExtremeXOS 16.1.
