This command configures the option interface-id as described in RFC-4649 to an IPv6 bootp relay/DHCP relay agent.
| bootprelay | BOOTP Relay Service |
| ipv6 | DHCPv6 BOOTP Relay Service |
| option | DHCPv6 BOOTP Relay options |
| interface-id | Interface identifier option. |
| interface_id_string | Interface identifier string. |
| none | Identifier defaults to 802.1Q VLAN ID. |
| all | All VLANs. |
802.1Q VLAN ID if not configured.
Use this command to configure the option interface-id as described in RFC-4649 to an IPv6 BOOTP relay/DHCP relay agent. After receiving an IPv6 BOOTP/DHCP request packet on the specified VLAN, the agent adds the configured identifier to the packet and passes it to the server. If this option is configured to be as system-name, the switch name is used as the remote-id. The same can be unconfigured using the none option. After unconfiguring this option, the switch MAC address (the default value) is used as remote-id. This option can be configured or unconfigured to a specified VLAN or to all VLANs.
* Switch # show bootprelay ipv6
BOOTP Relay: DHCPv6 BOOTP Relay enabled on virtual router "VR-Default"
BOOTP Relay Servers : 2001:0db8:85a3:0000:0000:8a2e:0370:7334
2001:0db8:85a3:0000:0000:8a2e:0370:7335
2001:0db8:85a3:0000:0000:8a2e:0370:7336
2001:0db8:85a3:0000:0000:8a2e:0370:7337
VLAN "Default":
BOOTP Relay : Disabled
VLAN "v1":
BOOTP Relay : Enabled
Interface ID : v1-12
Remote ID : v1_remId
VLAN "v2":
Interface ID : 100 (Default)
Remote ID : 00:04:96:52:A7:1B (Default)
This command was first available in ExtremeXOS 15.5.
