Use this command to display the active authenticated sessions for both policy and non-policy mode.
| all | Include sessions with 'terminated' status. |
| summary | Do not display detailed information. |
| mac-address | Specify a MAC address. |
| mac_address | Specify a MAC address. |
| ports | Port or range of ports. |
| agent | Specify an agent type. |
| dot1x | IEEE 802.1X Port-Based Network Access Control. |
| mac | MAC authentication. |
| web-based | Web-based authentication. |
| convergence-endpoint | Convergence-endpoint authentication. |
N/A.
None.
# show netlogin session summary Port Address type Address X W M C B ------------ ------------ ------------------------ --------- 23 mac 00:00:88:88:00:00 X 23 mac 00:00:88:88:00:01 X X 23 mac 00:00:88:88:00:02 X X 23 mac 00:00:88:88:00:03 X X 23 mac 00:00:88:88:00:04 X ------------ ------------ ------------------------ --------- X - dot1x W - web-based M - mac C - convergence-endpoint B - Blackholed in FDB
show netlogin session Multiple authentication session entries --------------------------------------- Port : 1:1 Station address : 00:04:f2:9f:48:fe Auth status : success Last attempt : Fri Nov 17 21:56:01 2017 Agent type : cep Session applied : true Server type : local VLAN-Tunnel-Attr : None Policy index : 2 Policy name : NProfile_16 (active) Session timeout : 0 Session duration : 2 days, 21:57:19 Idle timeout : 300 Idle time : 0:00:00 Auth-Override : enabled Termination time : Not Terminated Port : 15 Station address : 00:00:00:00:0b:00 Auth status : success Last attempt : Thu Jan 30 12:48:04 2020 Agent type : mac Session applied : false Server type : local VLAN-Tunnel-Attr : None Policy index : 0 Policy name : No Policy applied Session timeout : 0 Session duration : 0:00:04 Idle timeout : 0 Idle time : 0:00:00 Auth-Override : disabled Termination time : Not Terminated
This command was first available in ExtremeXOS 16.1.
Sessions shown for both policy and non-policy mode was added in ExtremeXOS 30.7.
