Displays operation statistics for the identity management feature.
N/A.
A user can login from multiple machines or ports, so the total number of login instances can be more than the number of unique users logged in.
The following command displays the identity management feature statistics:
Switch.4 # show identity-management statistics Total number of users logged in : 2 Total number of login instances : 2 Total memory used : 1 Kbytes Total memory used by events : 0 Kbytes Total memory available : 511 Kbytes High memory usage level reached count : 0 Critical memory usage level reached count: 0 Max memory usage level reached count : 0 Current memory usage level : Normal Normal memory usage level trap sent : 0 High memory usage level trap sent : 0 Critical memory usage level trap sent : 0 Max memory usage level trap sent : 0 Event notification sent : 0 Total number of roles configured : 3
This command was first available in ExtremeXOS 12.4.
