Configures the autopolarity detection feature on the specified Ethernet ports.
port_list |
Specifies one or more ports on the switch. |
on |
Enables the autopolarity detection feature on the specified ports. |
off |
Disables the autopolarity detection feature on the specified ports. |
| mdi-mode | Specifies to configure Medium-Dependent Interface (MDI) mode for the port. |
| default | Specifies to use the platform‘s default MDI mode. |
| mdi | Specifies to force straight-through or MDI mode for the port. |
| mdix | Specifies to force crossover or MDIX mode for the port. |
Enabled.
This feature applies to only the 10/100 BASE-T ports, and copper medium on combination ports.
When autopolarity is disabled and optionally a specific MDI mode is configured on one or more Ethernet ports, you can verify the autopolarity status and the MDI mode by using the following command:
# show ports information detail
The following command disables the autopolarity detection feature on ports 5 to 7 on a switch:
# configure ports 5-7 auto-polarity off
The following command disables the autopolarity detection feature and sets crossover or MDIX mode on ports 6 to 8 on a switch:
# configure ports 6-8 auto-polarity off mdi-mode mdix
The mdi-mode option was added in version 32.6.
