Shows the operational status of Integrated Application Hosting (IAH) guest virtual machines (VMs).
vm | Designates a virtual machine. |
vm_name | Specifies the VM name to add show information about. |
detail | Specifies showing detailed information. |
N/A.
The IAH feature requires the Solid State Storage Device SSD-120.
The following example shows information for VM "TPVM":
# show vm TPVM VM Name: TPVM State: Running Memory size: 4096 MB CPUs: 2 Auto-start: Enabled VNC: 127.0.0.1:2 (Port 5902) Disk: vda Source: /mnt/vmstorage/TPVM/TPVM.img Disk bus type: virtio Allocated size in bytes: 34359738368 (32.00 GB) Physical size in bytes: 4199288832 (3.91 GB) Read requests: 15947 Bytes read: 349533184 Write requests: 330 Bytes written: 4293632 Network interfaces: Attached switch ports: 33-34 CPU utilization: User: 10.00% System: 30.00% Memory utilization: Used: 0.05 GB Available: 3.95 GB
The following example shows information for multiple VMs:
# show vm S A Name |--Memory (GB)--| |----CPU-----| Ports Total Used Avail # Sys% User% - - -------------------------------- ----- ----- ----- -- ----- ----- ---------- * E TPVM 4.00 0.05 3.95 2 10.00 30.00 33,34,Mgmt D tpvm2 4.00 N/A N/A 2 N/A N/A None Status: (*) Running Auto-start: (D) Disabled, (E) Enabled.
This command was first available in ExtremeXOS 30.3.
Clarifications were made to memory and CPU usage information in ExtremeXOS 30.5.
Disk bus type information was added in ExtremeXOS 30.7.
This command is available on all platforms that support the Integrated Application Hosting (IAH) feature and have a Core or Premier license installed. For a list of platforms that support the IAH feature and for information about licenses, see the Switch Engine v33.1.1 Licensing Guide .
