show mvr cache
This command is provided for backward compatibility. The recommended command is:
show mcast cache {{vlan} vlan_name} {{[group grpaddressMask | grpaddressMask] {source sourceIP | sourceIP}} {type [snooping | pim | mvr]}| {summary}}
The syntax for the original form of this command is:
show mvr cache {vlan vlan_name}
Description
Displays the multicast cache entries added by MVR.
Syntax Description
vlan_name Specifies a VLAN name.
Default
N/A.
Usage Guidelines
If no VLAN is specified, information for all VLANs is displayed.
The following command displays the multicast cache in the MVR range for the VLAN vlan110:
Switch.78 # show mvr cache vlan110
This command display is the same as for the following preferred command:
show mcast cache {{vlan} name} {{[group grpaddressMask | grpaddressMask] {source sourceIP |sourceIP}} {type [snooping | pim | mvr]}| {summary}}
This command was first available in ExtremeXOS 11.4.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MVR feature, see the Switch Engine v33.1.1 Licensing Guide document.
