Resets the MVRP STP domain.
| mvrp | Multiple VLAN Registration Protocol. |
| stpd | The STP domain the VLAN is to be associated with. All ports of the domain will be advertised when this VLAN is registered. |
s0.
Use this command to reset the STP domain associated with a particular VLAN or all VLANs to default. If a VLAN is specified, the specific VLAN will be associated to the default STP, which is configured using the configure mvrp stpd stpd_name default command. If VLAN is not specified, all VLANs are associated to STP domain s0.
unconfigure mvrp stpd
This command was first available in ExtremeXOS 15.3.
