Allows you to delete a remote MEP for a specific MEP ID and MAC address.
| domain_name | Enter the domain associated with the MA you are configuring. |
| association_name | IEEE 802.1ag or ITU-T Y.1731 association name. |
| mepid | Enter the MEP ID of the remote MEP that is to be deleted. |
N/A.
Use this command to delete a remote MEP of an MA for a specific MEP ID.
Use the show cfm detail command to verify your configuration.
