Deletes a specified local network login user name and its associated password.
| user-name | Specifies a local network login user name. |
N/A.
Use the show netlogin local-users command to determine which local network login user name you want to delete from the system. The show netlogin local-users output displays the user name and password in a tabular format.
This command applies only to web-based and MAC-based modes of network login. 802.1X network login does not support local database authentication.
You must have administrator privileges to use this command.
The following command deletes the local network login megtest along with its associated password:
delete netlogin local-user megtest
