Displays network devices information for an Automation Edge remote VXLAN network identifier (VNI)-device database.
| automation | Displays Automation Edge VXLAN VNI-device database information. |
| edge | Specifies Automation Edge. |
| devices | Specifies network devices information, such as switches or APs. |
| vni | A unique 24-bit Virtual Network Identifier";% |
| vni | Virtual Network Identifier value between 1 and 16777215"; |
N/A.
This command shows the details about the network devices, including device identifier, IP address of the device, MAC address of the device, and the device type (access point or switch).
The following example shows network devices information:
# show automation edge devices VNI Device Name Serial Number IP Address Type ----- ------------------------ ------------------------ --------------- ------ 30 APName1 1111222233334444_110 200.200.200.10 AP 31 APName2 1111222233334444_11 200.200.200.1 AP
The following example shows network devices information for VNI "100":
# show automation edge devices vni 100 Device Name Serial Number IP Address Type ------------------------ ------------------------ --------------- ------ APName1 1111222233334444_15 200.200.200.5 AP APName2 1111222233334444_17 200.200.200.7
This command was first available in ExtremeXOS 31.1 as a demonstration feature.
This command is fully supported in ExtremeXOS 31.2.
This command is available on the ExtremeSwitching 5520 platform.
