Configures the IP address that is to be translated and the IP address to which this is to be translated for destination Network Address Port (NAT) rules.
| ip | Specifies Internet Protocol (IP). |
| nat | Specifies NAT. |
| rule | Specifies NAT rule. |
| rule_name | Specifies the NAT rule name. |
| destination | Specifies modifying the destination IP address. |
| dst_ip_addr | Specifies the destination IP address that needs to be translated. |
| new-destination | Specifies a destination IP address after translation. |
| new_dst_ip_addr | Specifies the destination IP address after translation. |
| vr | Specifies a virtual router (VR) on which the packet is sent out after translation. |
| vr_name | Specifies an existing VR/VRF name on which the packet is sent out on after translation. If not specified, the VR context from where this command is executed is used. |
| none | Deletes the IP address configuration. |
If no VR is specified, the current VR context is used.
This command configures the destination NAT rule address information. To configure the source information, run the command configure ip nat rule rule_name source [[[src_ip_addr src_mask | src_ipNetmask ] {{source-vr} src_vr_name} new-source new_src_ip_addr] | none].
The following example configures the rule named "ipOnlyRule" to translate the destination the IP address from 121.144.169.196 to 10.20.30.40. The egress VLAN is present in the VR "VR-user-out":
# configure ip nat rule ipOnlyRule destination 121.144.169.196 new-destination 10.20.30.40 vr VR-user-out
This command was first available in ExtremeXOS 31.2.
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.1.1 Licensing Guide document.
