show management
show management
Description
Displays the SNMP and CLI settings configured on the switch and the SNMP statistics.
Syntax Description
Default
N/A.
Usage Guidelines
The following management output appears:
  • Enable/disable state for Telnet, and SNMP access.
  • Login statistics.
    • Enable/disable state for idle timeouts.
    • Maximum number of CLI sessions.
  • SNMP community strings.
  • SNMP trap receiver list.
For ExtremeXOS 11.0 and later, the following management output appears:
For ExtremeXOS 11.1 and later, the following management output appears:
For ExtremeXOS 11.2 and later, the following management output appears:
  • Access-profile usage configured via ACLs for additional Telnet and SSH2 security.
For ExtremeXOS 11.6 and later, the following management output appears:
  • CLI scripting settings
    • Enable/disable state.
    • Error message setting.
    • Persistence mode.
For ExtremeXOS 12.4 and later, the following management output appears:
For ExtremeXOS 12.5 and later, the following management output appears:
  • CLI prompting.
  • SNMP INFORM.
For ExtremeXOS 22.1 and later, configured journal size (historical list of commands) appears.
For ExtremeXOS 22.3 and later, SSHv2 rekey interval time appears.
For ExtremeXOS 30.2 and later, CLI history expansion and port notation status appear.
For ExtremeXOS 30.3 and later, moved CLI commands information appears. The CLI hidden moved-keywords field shows:
  • Hidden—moved commands do not appear in the CLI.
  • Displayed with Help—moved commands appear with help text to direct you to the preferred new syntax.
  • Displayed with No Help—moved commands appear without help text to direct you to the preferred new syntax.
The CLI moved-keywords hidden release field shows if the switch has been configured to hide moved-commands, which version of ExtremeXOSversion was running when the hide command was issued. To clear the ExtremeXOS version in this field, execute unconfigure switch {all | erase [all | nvram]} using the all, erase all, or nvram option. This also sets the moved command option back to Displayed with Help.
The following command displays configured SNMP settings on a switch:
# show management
CLI idle timeout                 : Enabled (20 minutes)
CLI max number of login attempts : 3
CLI max number of sessions       : 8
CLI paging                       : Enabled (this session only)
CLI space-completion             : Disabled (this session only)
CLI configuration logging        : Disabled (with expansion)
CLI journal size                 : 100
CLI password prompting only      : Disabled
CLI hidden moved-keywords        : Displayed with Help
CLI moved-keywords hidden release: 30.3
CLI RADIUS cmd authorize tokens  : 2
CLI scripting                    : Disabled (this session only)
CLI scripting error mode         : Ignore-Error (this session only)
CLI persistent mode              : Persistent (this session only)
CLI prompting                    : Enabled (this session only)
CLI screen size                  : 24 Lines 80 Columns (this session only)
CLI refresh                      : Enabled
CLI history expansion            : Enabled
Current system port notation     : port
Configured system port notation  : port
Telnet access                    : Enabled (tcp port 23 vr all)
                                 : Access Profile : not set
SSH access                       : Enabled (Key valid, tcp port 22 vr all)
                                 : Secure-Mode    : Off
SSH2 idle time                   : 60 minutes
SSH2 rekey interval              : 4096 MB and no time limit
Web access                       : Enabled (tcp port 80)
Total Read Only Communities      : 1
Total Read Write Communities     : 1
RMON                             : Disabled
SNMP access                      : Enabled
SNMP Notifications               : Enabled
SNMP Notification Receivers  : None
SNMP stats:     InPkts 0       OutPkts   0       Errors 0       AuthErrors 0
                Gets   0       GetNexts  0       Sets   0       Drops      0
SNMP traps:     Sent   0       AuthTraps Enabled
SNMP inform:    Sent   0       Retries   0       Failed 0
The trap receiver source IP address, SNMP counter statistics, SSH access, CLI logging, and SNMP access states were added to the output in ExtremeXOS 11.0.
The enabled/disabled state for RMON was added to the output in ExtremeXOS 11.1.
Additional Telnet and SSH2 information about ACL usage was added to the output in ExtremeXOS11.2.
Information about CLI scripting including, the enabled/disabled state, error mode, and persistent mode was added to the output in ExtremeXOS 11.6.
The dropped SNMP packet counter (Drops) was added to the output in ExtremeXOS 12.4.
CLI prompting was added to the output in ExtremeXOS 12.5.
SNMP INFORM was added in ExtremeXOS 12.5.3.
Configured journal size (historical list of commands) was added in ExtremeXOS 22.1.
SSHv2 rekey interval time was added in ExtremeXOS 22.3.
Status of CLI configuration logging unabbreviated form (expansion) was added in ExtremeXOS 22.5.
CLI history expansion status and system port notation information were added in ExtremeXOS 30.2.
CLI moved commands information was added in ExtremeXOS 30.3.
Platform Availability
