Configures a range of IP addresses in an OSPF area to be aggregated.
| area-identifier | Specifies an OSPF area. |
| ip-address | Specifies an IP address |
| ip-mask | Specifies a subnet mask. |
| ipNetmask | Specifies IP address / Netmask. |
| advertise | Specifies to advertise the aggregated range of IP addresses. |
| noadvertise | Specifies not to advertise the aggregated range of IP addresses. |
| type-3 | Specifies type 3 LSA, summary LSA. |
| type-7 | Specifies type 7 LSA, NSSA external LSA. |
N/A.
If advertised, the aggregated IP range is exported as a single LSA by the ABR.
The following command is used to summarize a certain range of IP addresses within an area and export them out as a single address:
configure ospf area 1.2.3.4 add range 10.1.2.0/24 advertise type-3
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
