Sets the value for Neighbor Discovery Protocol (NDP) reachable time
| reachable-time | Specifies setting the NDP reachable time. |
| reachable_time | Sets the value for the NDP reachable time (range is 1–1,474,515,000 millisecond or 1–1,474,515 second). |
| auto | Specifies having the NDP reachable time set automatically to 3/4 of the configured NDP timeout (default). |
| milliseconds | When setting the reachable time value, specifies milliseconds as the time unit (range is 1–1,474,515,000). |
| seconds | When setting the reachable time value, specifies seconds (range is 1–1,474,515) as the time unit (default). |
The default setting is for the reachable time to be set automatically to 3/4 of the configured NDP timeout. If you set the time manually, the default unit of measure for the value is seconds.
configure neighbor-discovery cache reachable-time 500000 seconds
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
