Displays information about neighbors in ports.
| port_list | Specifies the port list, separated by a comma. |
| configuration | CDP local port configuration. |
| detail | Detailed information. |
N/A.
Use this command to display CDP port information.
The following command displays neighbor port information on the CDP feature:
# show cdp ports
Neighbor Information--------------------
Port Device-Id Hold time Remote CDP Port ID
Version
1 Eni-Extreme-switch-sw> 149 Version-1 Slot: 1, Port: 1
2 00:04:96:8B:9D:B0 160 Version-2 Slot: 1, Port: 2
7 00:04:96:8B:C1:ED 138 Version-2 Slot: 1, Port: 7
">" indicates that the value was truncated to the column size in the output.Local Port Information
Port Trust Cos VoIP VLAN VoIP VLAN
Advertise
1 Trusted 0 Default Solicited
2 Trusted 0 Default Unsolicited
# show cdp port 10 detail
Device ID : switch model
Port ID (outgoing port) : Slot: 1, Port: 10
Advertisement Version : 2
Platform : model name
Interface : 10
Holdtime : 162
Version :
ExtremeXOS version 22.4.0.5 xos_22.4 by kosharma
on Fri Jul 14 12:28:36 IST 2017
Native VLAN : 1
Duplex : Full
Trust : Trusted
SysName : switch model
This command was first available in ExtremeXOS 15.4.
The output of this command was updated in ExtremeXOS 21.1.
The detailoption was added and the output of this command was updated in ExtremeXOS 22.5.
