Disables network login logout window pop-up.
Enabled.
This command controls the logout window pop-up on the web-based network client. This command applies only to the web-based authentication mode of network login. When disabled, the logout window pop-up will no longer appear. However, if session refresh is enabled, the login session will be terminated after the session refresh timeout.
The following command disables network login logout-privilege:
disable netlogin logout-privilege
This command was first available in ExtremeXOS 11.1.
