Configures the RIPng garbage time.
| seconds | Specifies a time in seconds. Range is 10 to 2400 seconds. |
120 seconds.
This command configures the time interval after which a route in the RIPng routing database that has expired will be removed. The value is rounded off to nearest multiple of 10.
The following command configures the RIPng garbage time to have a 60-second delay:
configure ripng garbagetime 60
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
