Configures the rate limiting for protocol anomaly notification.
| value | Specifies the period of the rate limit. |
| slot | Specifies the slot to be used. |
| all | Specifies all IP addresses, or all IP addresses in a particular state. |
The default is 10 events per second.
This is a paired command with configure ip-security anomaly-protection notify rate window that configures the rate limiting for protocol anomaly notification. When the anomaly notification is enabled, in order to avoid overloading CPU, the system generates only the number of limited notifications in a period of window seconds. The range is from 1 to 100 events.
This command was first available in ExtremeXOS 12.0.
