Configures the timeout interval for RADIUS-Accounting authentication requests.
| mgmt-access | Specifies the switch management RADIUS authentication server. |
| netlogin | Specifies the network login RADIUS authentication server. |
| primary | Primary server. |
| secondary | Secondary server. |
| index | RADIUS server index. |
| seconds | Specifies the number of seconds for authentication requests. Range is 1 to 240 seconds. |
The default is 3 seconds.
This command configures the timeout interval for RADIUS-Accounting authentication requests. When the timeout has expired, another authentication attempt will be made. After three failed attempts to authenticate, the alternate server will be used.
The mgmt-access keyword specifies the RADIUS accounting server used for switch management.
The netlogin keyword specifies the RADIUS accounting server used for network login.
If you do not specify the mgmt-access or netlogin keywords, the timeout interval applies to both switch management and netlogin RADIUS accounting servers.
This example assumes the default number of retries of 3.configure radius-accounting timeout 10
The mgmt-access and netlogin keywords were added in ExtremeXOS 11.2.
