configure netlogin idle-timeout
configure netlogin idle-timeout {convergence-endpoint | dot1x | mac | web-based} timeout
Description
This command clears multiple authentication properties for one or more ports.
Syntax Description
dot1x IEEE 802.1X Port-based network access control.
mac MAC authentication.
web-based Web-based authentication.
convergence-endpoint Convergence-endpoint authentication.
timeout Number of seconds before idle timeout (range 0-172800).
Default
Timeout = 300 seconds.
Usage Guidelines
This command appears in show configuration {module-name} {detail} for "policy" rather than "netlogin."
This command was first available in ExtremeXOS 16.1.
Platform Availability
