Configures the TACACS+ accounting server.
| primary | Configures the primary TACACS+ accounting server. |
| secondary | Configures the secondary TACACS+ accounting server. |
| ipaddress | The IP address of the TACACS+ accounting server being configured. |
| hostname | The host name of the TACACS+ accounting server being configured. |
| tcp_port | The TCP port to use to contact the TACACS+ server. |
| ipaddress | The IP address used by the switch to identify itself when communicating with the TACACS+ accounting server. |
| vr_name | Specifies the virtual router
                                on which the client IP is located. Note: User-created VRs are
                                    supported only on the platforms listed for this feature in the
    Switch Engine v33.1.1 Licensing Guide
     document. |
Unconfigured. The default virtual router is VR-Mgmt, the management virtual router.
You can use the same TACACS+ server for accounting and authentication.
To remove a server, use the following command:
unconfigure tacacs server [primary | secondary]
The following command configures server tacacs1 as the primary TACACS+ accounting server for client switch 10.10.20.35 using a virtual router interface of VR-Default:
configure tacacs-accounting primary server tacacs1 client-ip 10.10.20.35 vr vr-Default
