Shows the NTP status of each VLAN configured on the switch.
| vr | Specifies showing NTP information for a given VR. |
| vr_name | Specifies which VR to show information about. If a VR name is not specified, the VR of the current command context is used. |
If a VR name is not specified, the VR of current command context is used.
N/A.
The following command shows the NTP status of VLAN "mgmt":
# show ntp vlan "mgmt" VR Name Vlan NTP Status Broadcast Server Key Index ================================================================================= VR-Mgmt Mgmt Disabled Disabled -
The following example displays all VLANs for VR "VR-Default”:
# show ntp vlan vr "VR-Default” VR Name Vlan NTP Status Broadcast Server Key Index ======================================================================= VR-Default Default Disabled Disabled - VR-Default vlan1 Disabled Disabled -
This command was first available in ExtremeXOS 12.7.
The vr keyword was added in ExtremeXOS 22.2.
