Resumes a virtual machine (VM) that has been suspended.
| vm | Specifies a VM. |
| vm_name | Specifies the VM name to resume. |
N/A.
When you resume a VM, the CPU state of the VM continues from the point at which it was suspended.
To suspend the VM again, use the suspend vm vm_name command.
The following example resumes the VM "vm1":
# resume vm vm1
This command was first available in ExtremeXOS 30.7.
This command is available on all platforms that support the Integrated Application Hosting (IAH) feature and have a Core or Premier license installed. For a list of platforms that support the IAH feature and for information about licenses, see the Switch Engine v33.1.1 Licensing Guide .
