Displays the difference between switch configurations.
| difference | Compare one configuration file to another. |
| from-config-file | Configuration file from which to base the difference (the booted configuration if not specified). |
| to-config-file | Configuration file to which the base configuration is compared (the running configuration if not specified). |
| module-name |
Configuration module name: aaa, acl, bfd, bgp, brm, cfgmgr, cfm, devmgr, dirser, dosprotect, eaps, edp, elrp, elsm, ems, epm, erps, esrp, ethoam, etmon, exsshd, fdb, hal, hclag, idMgr, ipfix, ipSecurity, lacp, lldp, mcmgr, mrp, msdp, netlogin, nettools, nodealias, nodemgr, ntp, ospf, ospfv3, otm, pim, policy, polMgr, pwmib, rip, ripng, rtmgr, snmp, stp, techSupport, telnetd, tftpd, throw, thttpd, twamp, upm, vlan, vmt, vrrp, vsm, xmlc, xmldbe |
| detail | Specifies showing configuration difference including default configuration choices; If not selected, default configuration information does not appear. |
| context | Adjusts the number of context lines around the difference output. Default is three lines. |
| lines | Specifies the number of context lines around the difference output. Default is three lines. |
If not specified, from-config-file is the booted configuration; if not specified, to-config-file is the running configuration.
If not specified, the default is three context lines.
Use this command to compare the difference between two configuration files, or configuration files with the running configuration. When using the save configuration automatic {every minutes {primary | secondary | existing-config | new-config} | never} command this can be especially helpful for comparing what changed between the running (or "startup") configuration and the most recently autosaved configuration.
# show configuration difference --- Factory Default Tue Feb 27 19:54:10 2018 +++ Running Configuration Wed Feb 28 12:37:36 2018 @@ -0,0 +1,212 @@ +# +# Module devmgr configuration. +# +configure snmp sysContact "support@extremenetworks.com, +1 888 257 3000" +# +# Module vlan configuration. +# +create vlan "VLAN_0008" +configure vlan VLAN_0008 tag 8 . . . +# +# Module vsm configuration. +#
# show configuration difference primary detail context 6 --- primary.cfg Mon Dec 4 18:08:59 2017 +++ Running Configuration Mon Dec 4 18:11:45 2017 @@ -608,13 +609,13 @@ disable cli scripting permanent configure idletimeout 20 enable idletimeout configure debug core-dumps internal-memory disable snmp traps configuration save disable snmp traps configuration change -save configuration automatic every 2 primary +save configuration automatic never # # Module dosprotect configuration. # disable dos-protect configure dos-protect interval 1
This command was first available in ExtremeXOS 22.5.
