Deletes a filter from a filter profile.
| all | Specifies all filters. |
| hex_profile_name | Specifies the filter profile of the filter to delete. The value is to be supplied as a colon separated string of hex octets. |
| profile_name | Specifies the filter profile of the filter to delete in ASCII format. |
| object_identifier | Specifies the MIB subtree of the filter to delete. |
N/A.
Use this command to delete a filter entry from the snmpNotifyFilterTable. Specify all to remove all entries. Specify a profile name to delete all entries for that profile name. Specify a profile name and a subtree to delete just those entries for that filter profile and subtree.
The following command deletes the filters from the filter profile prof1 that reference the MIB subtree 1.3.6.1.4.1:
configure snmpv3 delete filter prof1 subtree 1.3.6.1.4.1
The hex_profile_name parameter was added in ExtremeXOS 11.0.
