Configures whether counters need to be installed for Virtual Machine MAC which receives this VPP mapping.
| ingress-only | Only counts packets ingressing the switch whose source MAC address matches VM MAC. |
| egress-only | Only counts packets egressing the switch whose source MAC address matches VM MAC. |
| both | Counts packets ingressing and egressing the switch whose source MAC address matches VM MAC. |
| none | No packets will be counted. |
N/A.
Use this command to configure whether counters need to be installed for Virtual Lachine MAC which receives this VPP mapping.
Example output not yet available and will be provided in a future release.
This command was first available in ExtremeXOS 15.3.
