This command has been replaced with the following command: enable l2vpn [vpls [vpls_name | all] | vpws [vpws_name | all]] .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Enables the VPLS instance specified by vpls_name.
| vpls_name | Identifies the VPLS within the switch (character string). |
| all | Specifies all VPLS. |
All newly created VPLS instances are enabled.
This command enables the VPLS instance specified by vpls_name. By default, all newly created VPLS instances are enabled. When enabled, VPLS attempts to establish sessions between all configured peers. Services must be configured and enabled for sessions to be established successfully.
The following command enables the VPLS instance myvpls:
enable vpls myvpls
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
