Enables the STP protocol for one or all STPDs.
| stpd_name | Specifies an STPD name on the switch. |
Enabled.
If you want to enable the STP protocol for all STPDs, do not specify an STPD name.
The following command enables an STPD named Backbone_st:
enable stpd backbone_st
