configure cli password prompting-only
configure cli password prompting-only [ on | off ]
Description
This command allows you to configure prompting (with no echo) for all passwords, secrets, or keys.
Syntax Description
prompting-only Prompting is required when entering passwords, keys, and secrets. The default is off.
on Enable the option.
off Disable the option.
Default
Off.
Usage Guidelines
Use this command to configure prompting (with no echo) for all passwords, secrets, or keys. Each CLI command with password arguments will be modified to use the new mode (designated with flags="prompting-only" in the CLI syntax attribute specification). Prompting must be handled in the action script for that command.
This command was first available in ExtremeXOS 16.1.
Platform Availability
