This command disables IPv6 route compression.
| vr_name | Specifies a VR or VRF. If not specified, the current CLI context is used. |
By default, IPv6 route compression is disabled for all address families and VRs.
This command disables IPv6 route compression for the IPv6 address family and VR. This command decompresses previously compressed prefixes in the IPv6 prefix database.
The following example disables IPv6 route compression for the IPv6 address family and the VR of the current CLI context:
disable iproute ipv6 compression
This command was first available in ExtremeXOS 12.0.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
