enable dos-protect
enable dos-protect
Description
Enables denial of service protection.
Syntax Description
Default
The default is disabled.
Usage Guidelines
None.
The following command enables denial of service protection.
enable dos-protect
This command was first available in ExtremeXOS 11.1.
Platform Availability
