This command configures the VLAN tag and VR name for VPP. If the detected VM MAC uses this VPP, then the port in which the VM MAC is detected will be placed on this VR/VLAN.
| vpp_name | Specifies a name for the LVPP. |
| tag | Specifies a name for the VLAN tag. |
| vr_name | Specifies a name for the Virtual Router. |
N/A.
Use this command to configure the VLAN tag and VR name for VPP. If the detected VM MAC uses this VPP, then the port in which the VM MAC is detected will be placed on this VR/VLAN.
Example output not yet available and will be provided in a future release.
This command was first available in ExtremeXOS 15.3.
