Configures the reachable time value in router discovery advertisements on the VLAN.
| vlan_name | Specifies an IPv6 configured VLAN. |
| reachabletime | Specifies the reachable time value in advertisements, in milliseconds. Range is 0 to 3,600,000 (one hour). |
30,000 milliseconds.
The reachable time is the time, in milliseconds, that a node assumes a neighbor is reachable after having received a reachability confirmation. A value of 0 means the time is unspecified by this router. The maximum value is 3,600,000 (1 hour).
The following example configures the reachable time to be 3,600,000 milliseconds for the VLAN "top_floor":
configure vlan top_floor router-discovery reachable-time 3600000
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
