This command displays counters for an area or a VLAN.
| area_name | Specifies a router process for which to display the IS-IS counters. If you do not specify an IS-IS area, the software displays counters for all areas. |
| vlan_name | Specifies a VLAN for which to display IS-IS counters. |
| all | Displays IS-IS counters for all areas or VLANs. |
None.
If you enter the show isis counters command without any additional keywords or parameters, the software displays the counters for all areas.
The following command displays the IS-IS counters for the configured area:
show isis counters
The following command displays the IS-IS counters for the SJvlan VLAN:
show isis counters vlan SJvlan
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
