Configures a virtual router for a flow redirection policy.
flow_redirect_name | Specifies the name of the flow redirection policy. |
vr_name | Specifies the name of the virtual router. |
The default virtual router is VR-Default.
Because ACLs do not recognize the virtual router concept, one policy-based routing can be used for multiple virtual routing entries when a VLAN-based virtual router is used for one port. This configuration of a VR into a flow-redirect makes a policy-based routing work for a specific VR.
The following command configures virtual router mgmt for flow redirection policy flow3:
configure flow-redirect flow3 vr mgmt
Support for IPv6 flow-redirection policies was added in ExtremeXOS 12.7.
This command is available for IPv4 and IPv6 flow-redirection policies on the platforms listed for the Policy Based Routing feature in the Switch Engine v33.1.1 Licensing Guide document.
