Configures the LLDP port to advertise or not to advertise its system capabilities to its neighbors.
| all | Specifies all ports on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
| advertise | Specifies to send the information to neighbors. |
| no-advertise | Specifies not to send the information to neighbors. |
No advertise.
When at least one VLAN exists with more than two ports, bridging is sent to enabled.
When at least one VLAN on the switch has IP forwarding enabled, the system automatically sets the router bit.
The following command configures all ports to advertise system capability information to neighbors:
configure lldp ports all advertise system-capabilities
