configure iproute ipv6 priority
configure iproute ipv6 priority [auto-peering | ripng | blackhole | icmp | host-mobility | static | ospfv3-intra | ospfv3-inter | ospfv3-as-external | ospfv3-extern1 | ospfv3-extern2 | isis |isis-leve1-1 | isis-level-2 | isis-level-1-external | isis-level-2-external | ebgp | ibgp] priority {vr vr_name}
Description
Changes the priority for all routes from a particular route origin.
Syntax Description
auto-peering Specifies auto-peering routes.
ripng Specifies RIPng.
host-mobility Host-Mobility route.
blackhole Specifies the blackhole route.
icmp Specifies ICMP.
static Specifies static routes.
ospfv3-intra Specifies OSPFv3 Intra routing.
ospfv3-inter Specifies OSPFv3 Inter routing.
ospfv3-as-external Specifies OSPFv3 AS External routing.
ospfv3-extern1 Specifies OSPFv3 External 1 routing.
ospfv3-extern2 Specifies OSPFv3 External 2 routing.
isis Specifies ISIS routing.
isis-level-1 Specifies IS-IS Level 1 routing.
isis-level-2 Specifies IS-IS Level 2 routing.
isis-level-1-external Specifies IS-IS Level 1 External routing.
isis-level-2-external Specifies IS-IS Level 2 External routing.
ebgp Specifies EBGP routes.
ibgp Specifies IBGP routes.
priority Specifies a priority number in the range of 11 to 65534.
vr_name Specifies a VR or VRF name.
Default
The following table lists the relative priorities assigned to routes depending upon the learned source of the route.
Table 1. Route Priorities
Route Origin Priority
Direct 10
BlackHole 50
Static 1100
HostMobility 1150
ICMP 1200
OSPF3Intra 2200
OSPF3Inter 2300
IS-IS L1 2360
IS-IS L2 2370
RIPg 2400
OSPFv3 ASExt 3100
OSPFv3 Extern1 3200
OSPFv3 Extern2 3300
IS-IS L1 Ext 3400
IS-IS L2 Ext 3500
Usage Guidelines
Although these priorities can be changed, do not attempt any manipulation unless you are expertly familiar with the possible consequences. If you change the route priority, you must save the configuration and reboot the system.
The priority for a blackhole route can not overlap with the priority of any other route origin.
The following example sets the IPv6 route priority for static routing to 1200:
configure iproute ipv6 priority static 1200
The vr option was added in ExtremeXOS 12.1.2.
Platform Availability
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document..
