disable switch usb
disable switch usb
Description
Disables use of the switch's USB port.
Syntax Description
usb Specifies USB port on switch.
Default
Enabled by default.
Usage Guidelines
This command requires a reboot to take effect.
Stack support is not available. You need to run this command individually on each node in a stack.
Running unconfigure switch all removes this USB setting and returns to the default of enabled.
The following example disables use of the USB port:
disable switch usb
This setting will take effect at the next system reboot.
This command was first available in ExtremeXOS 22.3.
Platform Availability
