MLD snooping is not supported in this software release.Displays MLD snooping registration information and a summary of all MLD timers and states.
| name | Specifies a VLAN name. |
| detail | Displays the information in detailed format. |
| MLDv2 | Displays the MLD group in MLDv2 format (if group record is MLDv2 compatible, otherwise displays in earlier format). This option is not supported in this release. |
MLDv1.
The two types of MLD snooping entries are sender entry and subscribed entry.
Here is an example of the show output:
# show mld snooping MLD Snooping Flood-list : none MLD Snooping Proxy : Enable MLD Snooping Filters : per-port Vlan Vid Port #Senders #Receivers Router Enable -------------------------------------------------------------- Default 1 0 Yes v1 4084 0 Yes 25 1 Yes 41 2 No 42 2 No
The following command displays MLD snooping registration information for the VLAN V1:
# show mld snooping v1 Router Timeout : 260 sec Host Timeout : 260 sec MLD Snooping Fast Leave Time : 1000 ms VLAN v1 (4084) Snooping=Enabled Port Host Age Subscribed Join Limit 25 fe80::204:96ff:fe3a:ce50 13 ff02::1:ff3a:ce50 No Limit 25 fe80::204:96ff:fe3a:ce50 14 All Groups No Limit 41 fe80::200:8ff:fe55:5c27 13 ff02::1:ff00:2 No Limit 41 fe80::200:8ff:fe55:5c27 13 ff02::1:ff55:5c27 No Limit 42 fe80::200:8ff:fe56:5c2b 14 ff02::1:ff00:2 No Limit 42 fe80::200:8ff:fe56:5c2b 13 ff02::1:ff56:5c2b No Limit s = static MLD member #
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
