configure ports ingress-filtering
configure ports port_list mac-based-vlans ingress-filtering [on|off]
Description
Allows users to toggle the ingress filtering setting for MAC-based VLANs.
Syntax Description
port_list
Specifies one or more ports, or slots and ports.
mac-based-vlans
Specifies MAC-based VLANs.
ingress-filtering
Specifies the configuration of ingress filtering when MAC-based VLANs are enabled.
on
Turns on ingress filtering. Enabling ingress filtering prevents VLANs other than those with egress membership from being forwarded.
off
Turns off ingress filtering. Disabling ingress filtering allows the forwarding of packets sourced from any VLAN. This is the default setting.
Default
The default is off.
Usage Guidelines
If the command is executed on a port that does not have MAC-based VLANs enabled, the command will be accepted, but it will not be applied until MAC-Based VLANs are enabled.
The following command enables ingress filtering for ports 1:2:
# configure ports 1:2 mac-based-vlans ingress-filtering on
This command was first available in ExtremeXOS 31.5.
Platform Availability
