Clears, resets the CPU utilization history and statistics stored in the switch.
name | Specifies the name of the process. |
N/A.
When you do not specify any keywords, this command clears the CPU utilization history for the entire switch, including processes, and resets the statistics to zero (0).
When you specify process, the switch clears and resets the CPU utilization history for the specified process.
The following command resets the CPU history and resets statistics to 0 for the TFTP process running on a switch:
# clear cpu-monitoring process tftpd
